1. Login Failed 2. Spot Log not working.
k4jwa
#1 Posted : Friday, August 19, 2016 12:38:19 PM(UTC)
1) Logic will neither upload QSOs or download QSLs from LOTW.
2) Also, it is not receiving spots to the Spot Log.
Internet is functional on my computer and I am able to use my internet browser to connect and log into LOTW.
NOTE: When attempting to either upload QSOs or download QSLs message "Login failed. A browser...." appears.
Thanks for any help.
Jim - k4jwa
#2 Posted : Friday, August 19, 2016 6:05:50 PM(UTC)
Hi Jim:
Does any info appear in LOGic's LoTW window when you attempt to upload or download? The upload process is pretty much isolated from LOGic. It basically creates the ADIF file, and runs TrustedQSL for you. TrustedQSL actually does the transfer.
Make sure you have the latest LOGic and TrustedQSL. Based on the "Login failed" message, it sounds like you have an old version or LOGic. Uploading no longer actually logs in. Make an ADIF file, and try uploading it with TrustedQSL manually. That will verify the password and certificates etc are correct.
Where are you trying to receive spots from? Again, it will not download from DX Summit unless you have a fairly late version of LOGic.
