unworked entities
#1 Posted : Friday, August 12, 2016 7:33:06 AM(UTC)
Dennis, is there a way to have Logic report unworked entities (and ONLY unworked entities. Having unworked along with the rest of what I have worked isn't what I'm looking for) on a per band and/or per mode basis?
#2 Posted : Tuesday, August 16, 2016 8:10:27 PM(UTC)
You can filter the select criteria on the Awards report. Change the default select criteria
QSL_RCVD $ "SFRWU"
to
QSL_RCVD $ "U"
There is a little writeup about it in the run report form. You have to scroll down.
Don't overlook the CARDS NEEDED FOR AWARD report also. Very handy.
#3 Posted : Tuesday, August 16, 2016 9:26:08 PM(UTC)
OK, tried what you suggested (QSL_RCVD $ "SFRWU" to QSL_RCVD $ "U"), and Logic tells me there is nothing to report. In fact, I tried a couple different variations, and got the same message. Did I just find a bug?
#4 Posted : Tuesday, August 16, 2016 10:07:01 PM(UTC)
No, it definitely works. I think you need to go thru NEXT NEXT NEXT on the opening dialog and checkmark PRINT UNWORKED ENTITIES. (You had to have done that to get U printed as you described in your orig post).
#5 Posted : Wednesday, August 17, 2016 6:31:26 AM(UTC)
Got it. I hadn't checked the print unworked entities box...works better if you do that!
Many thanks!
WN4AZY on 2/27/2017(UTC)
