spotlog problem
#1 Posted : Tuesday, June 14, 2016 9:58:22 PM(UTC)
I have the band map in spotlog configured to ignore all vhf and higher bands, with the bands disabled and spotlog told to not process spots for these bands. When I log in to a telnet site, and do a sh/dx, if there are 6m and up spots it will still process and display these spots even though I said not to.
#2 Posted : Wednesday, June 15, 2016 11:41:13 AM(UTC)
Ok, are they just showing up in the band map, but not the spot log?
Double-check the band table to make sure PROCESS SPOTS FOR THIS BAND is unchecked. Note that there is more than one entry for most bands (CW & Phone). They all must be turned off.
Dennis WN4aZY
#3 Posted : Wednesday, June 15, 2016 3:36:25 PM(UTC)
Dennis, exactly backwards. They show in the dx spots IN SPITE of what is set up in the band table.
#4 Posted : Friday, June 17, 2016 8:40:25 AM(UTC)
Strange, can't reproduce that here. I unchecked PROCESS SPOTS FOR THIS BAND for both 6-meter segments, ran test spots, and no spots appeared. I tried it with and without the band enabled. I exited and restarted LOGic after changing the band table. Not sure if this is necessary or not.
Call me and I can log in and see if I see anything. 770-307-1496.
#5 Posted : Friday, June 17, 2016 9:18:14 AM(UTC)
Dennis, it only does this when you initially log in to any given telnet site and there are already v/uhf spots available. After that, if a v/uhf spot shows up on the telnet site, you don't see it.
