Installed update 8.0.104 and World Map error
#1 Posted : Friday, August 5, 2011 3:05:00 PM(UTC)
Hello,
I installed the latest update (8.0.104) and now LOGic 8 won't generate the world map.
I get the following error messages when I try to generate the World Map:
Class definition LOGICMAP8.SERVER is not found
(Cancel/Ignore/Help)
If I hit CANCEL, I go right back to my main logging page.
If I hit IGNORE, I get:
Unknown member MAP_REF
If I hit CANCEL, I go right back to my logging page.
If I hit IGNORE, I get the same error message:
Unknown member MAP_REF.
At his point, if I hit CANCEL or IGNORE, I go right back to my main logging page.
Help !!!!!
WN4AZY on 8/7/2011(UTC)
#2 Posted : Friday, August 5, 2011 3:25:50 PM(UTC)
I think you are the first poster! Sorry abt the problem, but thanks for that!
Here is how to fix that.
Run a DOS command prompt. Type CMD at the Search box or Start box. Type:
C:
CD \LOGIC8
LOGICMAP8 /REGSERVER
This problem was probably caused by User Acct Control being turned on during install.
See Here
#3 Posted : Friday, August 5, 2011 5:45:06 PM(UTC)
I followed your instructions:
Ran a DOS command prompt. Typed CMD at the Search box or Start box. Typed:
C:
CD \LOGIC8
and now I get the map window to open but it doesn't draw he map. I get a black semi-circle with a yellow dot in the middle of the window.
I set my AUC per your instructions as well. I am running Windows 7, typed UAC in the Windows Start Menu Search box. I clicked "Change User Account Control setting". The slider was already set to "Never Notify".
Anything else I should do to generate the world map?
Thank you very much for your time and help.
#4 Posted : Saturday, August 6, 2011 8:24:39 PM(UTC)
All you need to do now is tell it to draw. In the map window, click Options then Draw.
#5 Posted : Sunday, August 7, 2011 6:59:16 AM(UTC)
That worked BigGrin I now have my world map back again and showing all the spots when I use telnet.
Thank you for ALL your help !
