Start over costumizing all forms ???
OZ4CG
#1 Posted : Thursday, January 26, 2012 5:32:03 PM(UTC)
Carsten Gjessing
I now installed LOGic9, and almost all seems to be all right, BUT the communication to my TS590S is lost (But not to the FT857D ??)
And is it nessary to costumize all forms all over again??
I have spent hours and hours to costomize the logforms with userfields for several awards , and a nice QSL formula as well
PUHHHH - can I import this forms from LOGic8 ?? It cannot be right that all this work have to be done all over again ??
Vy 73 Carsten OZ4CG
#2 Posted : Thursday, January 26, 2012 9:43:06 PM(UTC)
Hi Carsten:
You can copy your LOGic 8 forms into LOGic 9.
http://hosenose.com/Foru...wnloadable-LOGic-9.aspx
The new Kenwood drivers may still be a problem. They were not working, and I changed something for the .27 update, and don't know if they work or not now. The old Kenwood (legacy) drivers are copied from LOGic 8 and do work.
Dennis WN4aZY
OZ4CG
#3 Posted : Friday, January 27, 2012 8:00:34 AM(UTC)
Carsten Gjessing
Hi Dennis
Thank you for your answer. It worked fine to copy the forms to LOGic9. Even my QSL is there BigGrin
I just have to reestablish USER7, USER8 and USER9, since MY RIG, Russian Oblasts and russian RDA's are not in the lists in LOGic9. But I guess I will manage that some time.
If it can be to some help, I can tell, that the KenwoodTS59S-rig only returns the Mcs, i.e. when I run 3,512 Mcs, it only writes 3,000 Mcs in the log.
There is another problem when I will open the CW-Keyer-form
I receive this message:
"Program Error:
OLE IDispatch exception code 0 from PDA.LOGic.CWKeyboard:
Method was not found: 'Boolean
PDA.Comport.Pool.Setup(System.String, Int16, Double, System.String,
Boolean, Boolean, Boolean)'..."
If I press "Cancel" the program shuts down, and if I press "Ignore" and try to set the COM-port etc. I get the same errormessage again....
Vy 73 Carsten /OZ4CG
