Error Caused by resizing Ten-Tec Pegasus (Disk File)
N6IE
#1 Posted : Sunday, April 24, 2016 8:46:58 PM(UTC)
Somehow when I was resizing the Pegasus control panel, I got an error that I can't recover from. When I start the program I get:
Error with kachina505_ole_controlpanel-form - FonSize: Expression evaluated to an illegal value.
I get several similar errors as I hit Ignore, and eventually the program starts, but there is a huge version of the Pegasus control panel that can't be closed without crashing the program. How do I fix this?
Ron, N6IE
N6IE
#2 Posted : Friday, April 29, 2016 8:34:18 PM(UTC)
Hello...anybody here?
N6IE
#3 Posted : Saturday, April 30, 2016 6:56:35 AM(UTC)
Ron,
Are you referring to the rig interface within LOGic? I don't have a Kachina or familiar with the Pegasus control panel.
Have you tried to turn off the rig interface and then back on?
Tools>Turn off radio & rotor interfaces
then
Tools>Reset or Turn On radio & rotor interfaces
If it's a control panel outside of LOGic this may not help. Did it work before? Recent upgrade?
Sorry if I'm not more helpful.
73 Kyle
N6IE
#4 Posted : Saturday, April 30, 2016 10:26:20 AM(UTC)
Kyle:
It's definitely within LOGic and the problem started when I tried to resize the radio interface window. The widow suddenly 'exploded' and is now something like 50 times the size it should be!
Ron, N6IE
#5 Posted : Sunday, May 1, 2016 6:58:29 AM(UTC)
Can you right click on the top bar of the window and "SIZE" it?
N6IE
#6 Posted : Sunday, May 1, 2016 2:00:11 PM(UTC)
I tried that and the window is so big, I can't get to the end of it! When I get close, the program crashes.
Ron, N6IE
#7 Posted : Monday, May 2, 2016 6:45:42 AM(UTC)
Sorry I am not familiar with the Ten Tec Pegasus Control Panel to help. When I search google I come up with N4PY software is this what you are using? I found one message about changing the X and Y for window size. Perhaps if there's a .ini file you can change to get the window back to normal. I'm at a lost, good luck.
73 Kyle
WN4AZY on 5/2/2016(UTC)
#8 Posted : Monday, May 2, 2016 8:18:45 AM(UTC)
Can't reproduce here, but I bet this will fix it. Go to the LOGic install folder (usually c:\program files (X86)\logic) and look for radio9.ini Look under the proper section (RADIO1, RADIO2...). Delete anything having to do with size or position.
[Radio 2]
RTS=Yes
DTR=Yes
DriverID= 38
StopBits=2
Visible=Yes
FormHeight=358
FormLeft=146
FormTop=266
FormMore=Yes
Using mine as an example, you would want to delete the last 4 lines.
N6IE
#9 Posted : Monday, May 2, 2016 2:35:29 PM(UTC)
That worked! Back to normal size now.
Ron
N6IE
