eQSL Picture Download
K8ZT
#1 Posted : Sunday, April 17, 2016 2:27:43 PM(UTC)
aluscre
About 2 weeks ago eQSL picture download stopped.
No changes to LOGic installation or Windows were made recently.
Confirmations are downloading as normal, but no pictures.
I have tried with both "Import eQSL Pictures" checked and unchecked and with"Import all Pictures" button (again with both "Import eQSL Pictures" checked and unchecked).
No error message just 0 pictures downloaded.
#2 Posted : Monday, April 18, 2016 8:57:53 PM(UTC)
Was thanked: 241 time(s) in 207 post(s)
I think but not sure this has something to do with eQSL. I noticed the last couple weeks I've been unable to Import to eQSL but today it worked. It appears maybe the trouble was with eQSL.
73 Kyle
WN4AZY on 4/21/2016(UTC)
#3 Posted : Thursday, April 21, 2016 10:33:10 AM(UTC)
I've had several reports for this. I was traveling but am back now and will take a look.
K8ZT
#4 Posted : Tuesday, April 26, 2016 5:56:55 PM(UTC)
aluscre
It still is acting the same way.
Things I tried:
1. Clean & Reindex LOGic
2. Checked to make sure eQSL account was working.
3.Tried different date in eQSL lookup
#5 Posted : Wednesday, April 27, 2016 8:22:17 AM(UTC)
Thanks for the research. I'm pretty sure the problem is universal, and that they changed something. Will be back in touch on this soon.
K8ZT
#6 Posted : Monday, May 23, 2016 11:33:49 AM(UTC)
aluscre
Any progress on this or is it an isolated problem that only I am having?
Anthony
K8ZT
#7 Posted : Saturday, June 4, 2016 9:49:37 AM(UTC)
aluscre
Is anyone else having this problem?
#8 Posted : Sunday, June 5, 2016 3:59:43 PM(UTC)
Have not been able to get pictures for 2-3 months. Running 9.0.86 on Windows 7.
#9 Posted : Sunday, June 5, 2016 8:00:59 PM(UTC)
What he said ^^^
K8ZT
#10 Posted : Sunday, June 12, 2016 10:53:50 AM(UTC)
aluscre
Any progress/ideas on this?
Anthony
#11 Posted : Monday, June 13, 2016 11:34:03 AM(UTC)
I just tried it, and it is working fine now!
Make sure you are logged in to eqsl.cc using the provided browser window when prompted.
#13 Posted : Tuesday, June 14, 2016 9:54:54 PM(UTC)
If you click on import all eqsl pictures in the update log tab, it tells me there are none to download.
K8ZT
#12 Posted : Friday, June 17, 2016 9:02:28 PM(UTC)
aluscre
I am still having the same problem.
I am using Windows 10.
Internet Explorer opens and I log in OK.
Clicking "Import all eQSL pictures" or simply having the "Import eQsl Pictures" both simply say no pictures downloaded
#14 Posted : Monday, June 20, 2016 6:49:21 AM(UTC)
Ok, I think I see what is going on.
Does the Update Log tab show any QSOs actually imported?
If you have QSOs in the log with no pictures, and want to go back and get those pictures, you will need to re-import those QSOs. The import pictures routine is only aware of QSOs handled in the current session. It is not aware of what is already in the log. Ok, there is a checkbox indicating if an imported QSO is already in the log, so let me just say that it is not aware of QSOs in the log that have not been imported in the current session. In other words, the QSO has to show up in the Update Log tab, and NOT FOUND IN LOG must not be checked.
Hope that makes sense.
#15 Posted : Monday, June 20, 2016 7:33:14 AM(UTC)
I did an update last night, and when I did it, I cleared the date out first. The pictures for the QSO's that were found imported fine.
K8ZT
#16 Posted : Tuesday, June 21, 2016 6:55:35 PM(UTC)
aluscre
I tried the following:
1. Used replace command to remove all sent eQSL records in the log back to 3-1-2016
2. Used replace command to remove all received eQSL records in the log back to 3-1-2016
3. Exported & Uploaded to eQSL
4. Imported from eQSL
a. It showed all of the calls with a eQSL to be filled in, I had the "import eQSL pictures" box checked
b. It asked me to log into eQSL, I did. It opened IE and I logged in.
c. I had the normal eQSL page showing in IE
d. When I clicked to continue, it updated all of the eQSL records, but did not import any pictures!
K8ZT
#17 Posted : Tuesday, June 21, 2016 7:04:46 PM(UTC)
aluscre
#18 Posted : Wednesday, June 22, 2016 11:41:02 AM(UTC)
Ok, you shouldn't even have to do any database commands to update eQSL Rcvd. I just blanked the date on the eQSL form to re-download everything, then clicked the Import Pictures button.
Here is something else I discovered: It isn't going to re-download a picture that already exists under any circumstances. I had to go to logic\logdata\log_pictures and delete a few picture files. It then recovered the missing picture files.
Are you sure you are actually missing any pictures?
Call me and I can log in and take a look. 770-307-1496.
P.S. -- on the missing or invalid telnet.fpt error, delete logic\data\telnet.dbf & telnet.fpt (keep a copy if you want), then reinstall the latest update.
K8ZT
#19 Posted : Thursday, June 23, 2016 6:52:58 PM(UTC)
aluscre
1. I went back and cleared all of the eQSL received checked boxes from 03/01/2016
use log
replace eqsl_rcvd with " " for QSO_DATE>={^2016-03-01}
2. I did import eQSL it retrieved calls with eQSLs (see the image with red "Before..")
3. I logged into IE successfully
4. It imported all of the records but not pictures (see the image with blue "After...)
K8ZT
#20 Posted : Thursday, June 23, 2016 7:09:24 PM(UTC)
aluscre
This series, I blanked date and then proceeded:
Guest (18)
This page was generated in 0.095 seconds.
