prop pitch
K8PG
#1 Posted : Tuesday, February 2, 2016 5:32:02 PM(UTC)
Hello all,
I am installing a prop pitch posistioner...
what do I select on type of rotator....
It has the mag counting type,
RT21 prop pitch... small reduction
Paul K8PG
#2 Posted : Wednesday, February 3, 2016 10:13:04 AM(UTC)
Hi Paul:
Do you have any sort of RS232 interface for your prop pitch motor?
I would be happy to work with you on the LOGic end -- whatever you need to go out the RS-232 port. We can also read the current heading if you provide that. If you can make it emulate a HyGain DCU1, that would work with LOGic as-is.
It seems that with the Arduino processor boards, homebrewing a solution would be a lot easier than it used to be.
