LOGic Forum
LOGic Support
All Other
Backup Dialog Box Off Screen
Posts: 18 Location: Chino California
Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
When opening the backup/restore log data dialog box from the tools menu, the dialog box opens off screen. The box can't be moved on screen and a backup can't be started. The normal windows tricks to move an off screen program back on screen do not work on the dialog box. Otherwise Logic works fine and any other dialog boxes are on screen and usable. Thanks for your assistance. Frank
Hi Frank--
You used to be able to click the CASCADE option that appears when you right-click the Windows task bar. However, it does nothing on my Win 10 machine. But you could try it.
Is the title bar totally invisible? I can't move mine off the screen.
The position is stored in the FORM.INI file located in the LOGic install folder. It is just a text file, so you can edit it in notepad. Or just delete it and LOGic will make a new one. All window positions and which windows are open will be lost.
Merry Christmas & 73,
The CASCADE option does not work on my Windows 7 machine either to bring the box back on screen. I edited the FORM.ini file to resolve the problem. Thank you for the assistance Dennis. Frank
LOGic Forum
LOGic Support
All Other
