Entity Framweork/VFPOLEDB Error
KA3LKM
#1 Posted : Saturday, December 19, 2015 11:24:23 AM(UTC)
entity framework database access error
the underlying provider failed on open
the VFPOLEDB provider is not registered on the local machine
this came up after I installed logic 9 update
I'm using windows 10 os
what do I do next
#2 Posted : Saturday, December 19, 2015 7:56:21 PM(UTC)
We had two or three other reports of this error. This fixed it for the first guy reporting it.
Download and run the VFP OLEDB provider and the VFP Entity Framework Provider.
http://distribution.hosenose.com/public/
Look for
VFPOLEDBSetup.msi
VfpEntityFrameworkProvider.msi
Not sure what the problem is -- it is definitely on the distribution. Let me know if you run into any problems running the VFPEntityFrameworkProvider.
W3KL
#3 Posted : Saturday, December 19, 2015 11:14:05 PM(UTC)
do I install this before or after I install 80?
W3KL
#4 Posted : Saturday, December 19, 2015 11:23:59 PM(UTC)
Windows says I already have the framework installed.
What do I do next? Still running 79
kf4bq
#5 Posted : Sunday, December 20, 2015 9:12:59 AM(UTC)
Computers all said that was already installed here too. Went to Cnt Panel/Add remove Programs and uninstalled... Then ran the one you provided. Still the same errors on Logic9. Crashes after index rebuild.
Mike and Peggy KF4BQ and KM4KKU
#6 Posted : Sunday, December 20, 2015 10:30:33 AM(UTC)
Installing it before or after installing the update should make no difference.
I also added another necessary component to my first post of this thread (VFPOLEDB). Perhaps that isn't getting installed. It does not show up in Programs and Features BTW.
You can also try installing them As Administrator.
I modified the install program to show a dialog upon completion. It also explicitly installs them AS ADMINISTRATOR. It should have been installing everything as administrator anyway, however. Anyway, I would try reinstalling using the new installer first.
http://www.hosenose.com/...and-fixes.aspx#post5410
kf4bq
#7 Posted : Sunday, December 20, 2015 11:40:45 AM(UTC)
Installed both .msi files. No luck. Couldn't install as admin since the compatibility privilege settings are grayed out. Reinstalled the .80 update with admin and still the same.
Uninstalled Logic9 and reinstalled 9.0.72, reloaded saved log stuff and com ... Now back running again with orig version. Will wait and see what happens.
Mike
#8 Posted : Monday, December 21, 2015 11:23:53 AM(UTC)
I found a machine here locally that I could reproduce the problem on. Win 7, 32-bit. Working on it now. Stay tuned!
#9 Posted : Monday, December 21, 2015 2:52:33 PM(UTC)
Ok, I think we're good now. I got it to run on the old computer, and was able to reproduce the conditions and fix it on my dev machine. I even ran it without Admin privileges and with User Account Control full-on.
So give this a try:
kf4bq
#10 Posted : Monday, December 21, 2015 7:09:07 PM(UTC)
Updated with new .80 and all fine here at KF4BQ now.
Thanks, Mike
