Posts: 18 Location: Utah
I have found two issues with Logic 9.
First- Logic 9 is supposed to support the FT5000 rotor. I do not find FT5000 in the drop down list of supported rotor drivers.
Second- If I start Logic 9 with the radio turned OFF, the timeout time before Logic 9 starts is way, WAY too long. 5 seconds should be enough.
Russ, W7AO
Sorry, the FT-5000 rotor control has not been implemented yet. Thanks for pointing this out. I have the driver and just need to marry it to the setup file. Should happen this weekend.
How log is the timeout taking?
It is taking 15 seconds to start. Version 8 starts in 4 seconds with the radio off.
