Posts: 464 Location: Missouri
Thanks: 98 times Was thanked: 154 time(s) in 137 post(s)
Dennis, the current S79C operation is from a previously unactivated IOTA - AF-119. If I try to add this to the user iota field, it tells me that AF-119 doesn't exist. AF-119 does show up in the list of valid values. How can I fix this? 73 Doug W5GA 73 Doug W5GA
Groups: Administrators, Beta Testers Posts: 3,234  Location: Auburn, GA Thanks: 1125 times Was thanked: 547 time(s) in 457 post(s)
The IOTA list is not up-to-date -- it still shows it as UNACTIVATED. http://www.rsgbiota.org/xml/fulllist.xml
So download the IOTA list again just to make sure you have the latest, then go to List of Valid Values, pull up AF-119, then uncheck UNACTIVATED. Exit and restart just to be safe. Tnx & 73, Dennis WN4AZY
