Progress and SpotLog windows
#1 Posted : Sunday, October 11, 2015 4:14:48 PM(UTC)
Hello Dennis,
the data in the SpotLog do not coincide with those of progress window.
I am attaching the screenshot where you can see that Guantanamo Bay is missing in 20 meters for the Challenge.
Why SpotLog it does not put "20" and "PHONE" in red ??
I was wrong setting ?? Thank you.
#2 Posted : Monday, October 12, 2015 11:43:02 AM(UTC)
Ok, the first thing I see is that you mention Challenge in your text, but the header of the Progress window shows just plain old DXCC. Click SEL in the Progress window, and select the Challenge subaward. I don't see the Subaward column in your screen shot, but I am assuming it is Challenge because you say it is hihi.
Also, check SPOT LEVEL in Options. It will affect the coloring. The most conservative option is QSL HAS BEEN RECEIVED.
Also, this doesn't come up very often, but I will mention it. The coloring of a spot record is accurate as of the time the spot is received. If you receive a spot and need KG4 on Phone, Phone will be red. If you then go and enter a card for a KG4 phone QSO, the Progress form will reflect that, but the spot log will not until you receive a new KG4 spot.
Note that you can test easily using the TEST SPOT feature of the spot lot.
#3 Posted : Monday, October 12, 2015 2:29:06 PM(UTC)
Hello Dennis,
I followed your instructions and I did the test.
I got the result we see in screenshots.
