LOGic Forum
LOGic Support
Logging
How to Add Standard Field (TX Power) to LOG:MAIN (browse) Form?
Posts: 6 Location: The Villages, FL 32163
How can I add a standard field (not a user-defined field) to LOGic9's "LOG:MAIN (browse) Form" (window)?
I would like to add the standard field of "TX Power" to LOGic9's "LOG:MAIN (browse) Form". The corresponding DATA ENTRY log form already has the "TX Power" (standard) field and allows me to enter values into it. However, I can not figure out how to add this "TX Power" field as a new column in the browse (LOG:MAIN) form.
Tony/N8SK
Posts: 627 Location: Mentor, OH
Thanks: 151 times Was thanked: 241 time(s) in 216 post(s)
Hi Tony,
This standard field is already in the logform browse window, it just may not be visible without scrolling to see it. While in the browse window just use the scroll bar at the bottom of that window to move to the right till you can see it. Once found you can move that column to the left (or right for that matter) to put it where you want.
Hope that helps,
73, de Brad, N8GLS
Hi Brad/N8GLS,
Thank you for your recent reply to my inquiry but I'm afraid I asked the wrong question (probably up to late typing it in while in "zombie" mode):-) You are right "TX_Power" is in the browse window but what I should have asked about is "FREQ_TX".
I am looking for how to add the "standard" field of "FREQ_TX" (not "TX Power" which I incorrectly entered in my initial post on this topic). LOGic's log data entry form allows me to manually enter "Freq" and "Freq TX" but I only see a column labelled "Freq" in the log browse window. I've scrolled the entire length of the browse window and it's just not there.
Tony/N8SK
It's missing. Sorry. IT'll have to add it.
73, WN4AZY
LOGic Forum
LOGic Support
Logging
