Importing SRX data
#1 Posted : Monday, June 15, 2015 3:15:01 AM(UTC)
importing data from contest program, the field SRX (Character field type) does not consider the "0" if it is the beginning of the field.
example:
<SRX: 4> 0006 only 6 matter.
How can I do to avoid manually edit all fields that begin to 0?
Thanks Mauro
#2 Posted : Monday, June 15, 2015 12:22:10 PM(UTC)
Try this.
Set the field type to character in tools\setup\log fields, then import. Then switch it back to numeric after the import.
This is a bug that I wasn't aware of. I will try to reproduce it here so I can fix it.
Let us know.
