Logic 8 problem with uploading to LoTW
pa3djy
#1 Posted : Monday, June 1, 2015 8:50:32 AM(UTC)
Hello all,
Since short I have an problem with uploading my qso's to LoTW and eQSL.
When I follow the standard procedures (location, date en password)
I end up (after automatic log in on LoTW site) with an "Upload failed" message.
After that I have to shut down Logic and start up Logic(8)again.
The strange things is, that if i check the LoTW site that all my qso's are
uploaded! All the QSL sent boxes aren't been checked after the upload so I
have to do this manualy via a database command.
The same applies for eQSL, only then i got the message Error "OLE errorcode
0x800706b5: The interface is unknown" "has occurred in program MYWEBROWSER. NAVIGATE, line 0.
Attempt to continue?"
I can see that both datafiles (Lotw and eQSL) and a tq.8 file are stored in de Logic/tmp map.
At this moment I have to remove those files after every manually upload and then
resetting my log via the database command use log - replace all eQSL_sent with .t.
and replace all lotw_sent with .t.
This method works but is rather time consuming hi
I run Windows 8.1.
Any idea what could be wrong?
Gerrit
de PA3DJY
#2 Posted : Monday, June 1, 2015 8:23:08 PM(UTC)
Hi Gerritt:
See here:
http://www.hosenose.com/...-uploading-to-LOTW.aspx
Tnx for using LOGic.
pa3djy
#3 Posted : Thursday, June 4, 2015 5:11:22 AM(UTC)
Hello Dennis,
Thanks for your quick reply.
I miss the eQSL part in the referred clarification,do you have any suggestions for this OLE error ?
Regards,
Gerrit
PA3DJY
#4 Posted : Thursday, June 4, 2015 3:07:38 PM(UTC)
Sorry, there is probably nothing that can be done about this in LOGic 8. We just made some recent changes in LOGic 9 to accommodate eQSL.
pa3djy on 6/6/2015(UTC)
pa3djy
#5 Posted : Saturday, June 6, 2015 4:55:26 AM(UTC)
Thanks for the help Dennis.
73's
Gerrit
PA3DJY
