Startup error--after installing the update
N7IP
#1 Posted : Sunday, January 22, 2012 3:26:14 PM(UTC)
I had Logic9 working but now when I try to start it, get the attached error messages. If I click thru the error windows using "cancel", the program quits. Tried re-installing and same result. So can't use Logic anymore....
I tried to attach a PDF of the screen shot but this forum gives error that PDFs are not allowed!!! Seems like that really inhibits our ability to share documents, including screen shots.
Logic9 error screen.png (2,196kb) downloaded 136 time(s).
w1gud
#2 Posted : Monday, January 23, 2012 10:54:46 AM(UTC)
This is the same issue I have with 9... I reinstalled with the patch file Dennis sent... same result...
at least I can now get my logic 8 to run stable again...
no joy with logic 9 however..
73, WArren W1GUD
#3 Posted : Monday, January 23, 2012 3:26:50 PM(UTC)
http://hosenose.com/Foru...n-----is-not-found.aspx
I fixed the forum to accept PDFs. Haven't tested it yet.
I'll call you later and get LOGic 9 running.
#4 Posted : Tuesday, January 24, 2012 9:28:04 AM(UTC)
Ok, looks like the missing UNACTIVATD field error is caused by copying over the LOGic 8 lists.dbf file.
I put an install startup script in the update to fix this.
http://hosenose.com/Foru...his-update.aspx#post481
N7IP
#5 Posted : Tuesday, January 24, 2012 2:01:50 PM(UTC)
Thanks Dennis. The fix enables v9 to install now. Am I correct that during the upgrade process we should copy the Logic8 LISTS and PREFIX files into the Logic9 directory? I don't see any functions for import or migrate from v8.
Bob
#6 Posted : Thursday, January 26, 2012 1:04:04 PM(UTC)
We redid the lists and prefixes table, including USSR changes and ST0.
We don't recommend it, but you can copy them if you want to.
The lists table has new tables for FFMA and CQ Field which are not downloadable. So unless you don't care about these, you could export them to somewhere, copy your table, and import. Or better yet export your custom lists from LOGic 8 and import into 9. Thre are buttons on the lists form for this purpose.
