It works fine here, so there is probably some anomaly with your printer driver -- for some reason it thinks that there is not enough room on the page to fit the header plus 10 rows, so it flows to the next page prematurely.
Modify the report and check that the height of the Header is .5" and the height of Detail is 1.0". Right-click on the bar that says Page Header or Detail. Properties, then General. Maybe they got changed somehow.
If they are correct, you need to shrink the content slightly. The easy way would be to set the page header to slightly less than .5". However, that will move the tops of each label up slightly, which may or may not be a problem.
You can also shorten the height of the Detail slightly. The problem here is that this will cause each label to creep up as you go down the page. Check the distances between the tops of labels -- it should be exactly 9" between the top and your last (9th). If it is a little more than 9", then the printer driver is not calculating distances properly, and shortening the detail a bit so that they do measure exactly 1" each is the proper fix.
You might check for an updated printer driver.
Unfortunately this sort of thing isn't that uncommon. Gotta love LoTW hihi.
Let us know.
