Ok, good news!
Attached is the LOG.dbf and log.dbt which I restored from the LOGic 4 backup you sent. Download the attached, unzip, and save the contents where you can find it. In LOGic 9, select tools/import/logic 3 and 4. It asks if you want LOGic to scan for LOGic 4 data. Say NO. Locate the data yourself.
I just tested to see that it did indeed import. I didn't review the data very carefully. Let me know if you see any problems.
In case anyone is interested how I was able to restore the LOGic 4 backup: As you know, Windows 7, at least the 64-bit version, will not run 16-bit programs. I worked around this by installing Windows XP mode on Win 7 Pro, installing LOGic 4 DOS to that, doing the restore, then getting log.dbf and log.fpt.
LOG.zip (51kb) downloaded 105 time(s).
