Telnet prompt/response
#1 Posted : Sunday, January 22, 2012 10:56:39 AM(UTC)
Is it possible to increase the field size? The size they are now doesn't allow enough room to use dx cluster commands. Example:
"set dx filter" will fit, but not with anything useful following to make that command do something. So it doesn't allow tailoring the telnet display short of writing a script.
Here's a list of commands for AR Cluster
AR Cluster
#2 Posted : Sunday, January 22, 2012 12:12:01 PM(UTC)
Sure, no problem. Will post this change in today's update.
However, you will still have to modify your telnet file. You can do this now if you want.
CLOSE all telnet forms.
Go to tools/advanced/database commands. Type
USE TELNET EXCLUSIVE
MODIFY STRUCTURE
Make the PROPMT fields 32 characters long
Make the RESPONSE fields 254 characters long
#3 Posted : Sunday, January 22, 2012 3:11:07 PM(UTC)
OK, did that. Now when I put a command in the response field that exceeds your as delivered field width, it wraps into the next lower prompt field. Apparently this causes the command to truncate when sent.
Is that the part you need to modify in an update?
#4 Posted : Sunday, January 22, 2012 3:25:53 PM(UTC)
Yeah, you need to download and install the update now.
http://hosenose.com/Foru...nstall-this-update.aspx
