Problem exporting to eQSL
#1 Posted : Monday, February 23, 2015 1:47:54 AM(UTC)
Was thanked: 80 time(s) in 75 post(s)
For the last month or more, I have been unable to export to eQSL. I get the following error after a long delay:
OLE IDsipatch exception code 0 from System: The remote server returned an error: (500) Internal Server Error...
Anyone else having this problem? Is there a solution?
#2 Posted : Tuesday, February 24, 2015 11:47:52 AM(UTC)
Having no issues here using 9.0.71.
73 Kyle
#3 Posted : Thursday, February 26, 2015 9:23:32 AM(UTC)
This sounds like a web server error. Try again.
#4 Posted : Tuesday, March 3, 2015 12:21:22 PM(UTC)
Still having the problem. Running 9.0.71. What else might the problem be? All other functions and programs work fine.
#5 Posted : Wednesday, March 4, 2015 7:52:01 PM(UTC)
The next thing to check is that there is not any internet protection software blocking LOGic from using the internet. Try turning that sort of stuff off temporarily. But you'd think if that was the case other things would not be working either.
I would go thru the process manually and see if that turns up anything.
http://www.hosenose.com/...ing-LoTW-and-LOGic.aspx
Also, 500 is a common server error. I would call ARRL and see if anyone else has reported any 500 errors.
At what step in the process does the 500 error occur? When uploading the TQ8 file I would assume....
