ADI format for FOC
#1 Posted : Tuesday, February 10, 2015 9:43:10 PM(UTC)
I operated the FOC contest last weekend using N1MM+. The adif file generated by N1MM+ produced a field name for the FOC numbers that is not recognized by LOGic. What is the official adif field name for FOC numbers? Is it 'FOC' (i.e. <FOC:4>1953)?
#2 Posted : Wednesday, February 11, 2015 10:05:26 AM(UTC)
Hi Allen,
adif name is FOC#. You have to substitute the string "FOC:" in the N1MM adif file with the new "FOC#:"
You must create a list of valid value importing the dbf file attached.
Reindex and pack.
In the FOC dbf file I inserted all the members with the appropriate nummbers as the 2015 official web listing.
You must add in the logform a new field called FOC# max 5 spaces located where you prefer.
After importing the N1MM modified adif file you can see in the logform all the FOC members qsos with FOC numbers filled.
I hope you understand my poor english.
All the best 73's IKØCHU Mauro
FOC.dbf (84kb) downloaded 135 time(s).
#3 Posted : Monday, February 16, 2015 4:36:11 AM(UTC)
Thanks Mauro. You are correct as usual hihi.
For future reference, to see what LOGic calls any field, go tools/setup/log fields. You can map any ADIF name to what LOGic uses in the ADIF tab. I prefer Mauro's method, but you'd be surprised how many people don't know hoe to use notepad hihi.
#4 Posted : Monday, February 16, 2015 3:07:15 PM(UTC)
I replaced N1MM's default ADIF name with "FOC#", deleted the FOC contest log records from my LOGic database and re-imported the revised ADIF file and all is good. Thanks!
