LOGic Forum
LOGic Support
LOGic 9 Installation and Upgrading
Logic 9 Restore Didn't Recognize Secure Digital Card
Posts: 7  Location: Knoxville, TN Thanks: 2 times
I am running Windows 7 on a Macbook Pro OSX Lion using Parallels. Logic 9 installed with no problem. When I went to install my backup log using the Restore function, the SD card was not recognized/identified in the drop down list of drives. The Macbook did identify the SD card as a device, and as a workaround, I moved the backup log from the SD card to drive C: and then did restore from drive C:
When using Logic 8, I was able to backup and restore directly to/from an SD card. I am not sure why my Logic 9 did not show me the SD card in the drop down list when using the Restore function.
Any suggestions appreciated.
Thanks for the report.
Do you have LOGic 8 on the same setup, and does it work? The closest test I can do is to use a flash drive in Win 7, and that works.
A possible workaround is to use ADVANCED which uses a different file selector to locate the drive.
Additional Information: Logic 9 is a clean install on a new Macbook Pro (no Logic 8 previously installed).
I do not have the SD card issue with my other, 2-year old, Macbook Pro that uses OS 10.6.8 and Windows 7 under Bootcamp with Logic 8. I repeatedly backed up and restored my Logic 8 logbook using an SD card between this 2-year old Macbook and and another Windows tower computer.
I'll get a fresh SD card and experiment. Also, this behavior may change once I get both computers on Logic 9.
The issue of not recognizing the SD card appears to be related to the Parallels software and NOT Logic 9. I will contact Parallels technical support for help. There is some indication on the web that failure to recognize the SD card is an open issue experienced by others using Parallels.
LOGic Forum
LOGic Support
