Can't import FCC/CA Callbook in Logic8
k6sgh
#1 Posted : Sunday, November 30, 2014 3:02:39 PM(UTC)
i tried to update the fcc callbook...it downloaded fine and created a zip file l_amat.zip in the /tmp folder.
when i hit the process tab in the import fcc callbook window, it runs a query and then an error message pops up that says "Uncompression failed. ZIP file ... does not exist".
the path is correct and the file exists. i also checked the zip file and the data looks fine. i've downloaded the file several times just to be sure.
same thing is happening to the import Canada book.[img]null[/img]
any ideas on how i can fix this?
many thanks...
Steve
k6sgh
#2 Posted : Sunday, November 30, 2014 3:44:12 PM(UTC)
i downloaded the l_amat.zip file directly from the FCC, put it in the tmp directory and voila...that worked ok.
