No way to stop a keyer memory from sending
W7OO
#1 Posted : Wednesday, November 26, 2014 2:44:22 PM(UTC)
The help file (in LOGic) for the keyer function says the following "If you start transmitting while a repeated command is in effect, the rest of the message is discarded and repeat is discontinued. In other words, if you are in a repeating CQ command, and someone answers, just reply as usual, and repeat is canceled automatically."
This does not work. In fact I can find no way to stop a memory from being sent once it is started.
I am running .71 release.
Is there a solution for this?
Bill
W7OO
#2 Posted : Thursday, December 4, 2014 1:12:57 PM(UTC)
Hi Bill:
Sorry, will check it out. Note that this is for REPEATED commands only, but even that isn't working for me either.
To stop transmission at any time, use the red X Cancel function in the keyer form or the keyer toolbar.
#3 Posted : Thursday, December 4, 2014 1:35:00 PM(UTC)
It would be nice if {ESC} immediately cancels a CW message, regardless of which window is open.
#4 Posted : Thursday, December 4, 2014 5:03:49 PM(UTC)
That would be difficult. {Esc} does different things on different forms. On the Log form, it does Undo for example. I think it will cancel CW, IF the Keyer form is current. I guess if CW was running, it could cancel that, otherwise do what it does now. But what if you want to say Undo and not cancel CW?
W7OO
#5 Posted : Thursday, December 4, 2014 5:37:40 PM(UTC)
Currently the Escape key does not cancel the sending of a CW memory.
I agree with Allen, if you could make the Escape key stop whatever the CW keyer was sending it would be most beneficial.
I could settle for having it interrupt a memory that was being repeatedly sent (like calling CQ until the Escape key was depressed).
Thanks for considering this.
Bill
W7OO
