Data in the Spot Log
#1 Posted : Sunday, November 23, 2014 3:07:51 PM(UTC)
the Spot Log grid make easy what we needed coding the values data in Red color and/or underlined.
There is in the screenshoot an example what happens.
The Spot Log seems i need CU7MD station in the 17M/Phone Mode combination. Also need as LOTW.
It's false because you can see i have 4 qsos with that station and one also in 17m and phone. That qso was confirmed also in lotw.
Can you explain me what would be the reason for the problem ?
Thanks and 73's de IKØCHU Mauro
#2 Posted : Sunday, November 23, 2014 5:51:53 PM(UTC)
Hi Mauro,
I think the clue is in the Award column and perhaps the Value column.
The Spot log seems to be saying you need 17m Phone for the LOTW Award? What is the LOTW award?
Also - what is the Y in the Value column to the left of the Band column.
Have a look into the Log field setup for the LOTW field - is it marked "track award" for this field????
IK0CHU on 11/23/2014(UTC)
#3 Posted : Sunday, November 23, 2014 7:52:13 PM(UTC)
Hi Peter,
another goal ....
I disabled the "tracks award" in LOTW user and it seems that all is well.
Now it is late and will check better tomorrow but I am sure that the problem was right where you have indicated.
This page was generated in 0.345 seconds.
