Radio Interfacing Issue
K8ZT
#1 Posted : Saturday, January 21, 2012 11:11:57 AM(UTC)
aluscre
I have not been able to get Radio interface working to Elecraft K3.
I had it working with LOGic8.
K3 Interfacing issue
1 user thanked K8ZT for this useful post.
EI7BA on 1/23/2012(UTC)
#2 Posted : Saturday, January 21, 2012 11:48:56 AM(UTC)
Scroll down and select the legacy Kenwood 850 driver the K3 driver does not work.
EI7BA
#3 Posted : Saturday, January 21, 2012 11:57:52 AM(UTC)
Groups: Beta Testers, Registered
Hi Folks!
I have a similar problem with my FT5000.. Similar screens and messages to K8ZT, except it's "FT5000.INIT"
Also, my Spots window refuses to open, giving "variable AWARDMODE not found", followed by "unknown member SPOTLOGREF"
If I try to reopen the Spots window, the program crashes.
I'm running Win 7 64bit.
Vy 73
John EI7BA
#4 Posted : Saturday, January 21, 2012 1:58:09 PM(UTC)
Same exact problem here as K8ZT with my K3, same baud rate, etc. I didn't try different baud rates, though.
W3KL
#5 Posted : Saturday, January 21, 2012 2:43:25 PM(UTC)
My problem is that it won't open the "Misc ham setup..." window.
Running XP.
#6 Posted : Saturday, January 21, 2012 7:54:58 PM(UTC)
Ok, sorry. Someone reported that the new 850 driver works minus the VFO B button, but turns out he was in fact using the 850 legacy driver unknowingly. So I will get the new Kenwood driver working, then a special K3 driver will follow shortly.
So use the legacy driver for now. There is also OmniRig. However, the only thing I have confirmed wrong with the 850 driver is that the VFO B button needs to be removed (not supported by the rig), and A=B not working. Not sure if OmniRig supports A=B or not....
Thanks for the screen shots. They will help immensely.
EI7BA: Sorry, please download again. Fe emailed you. Our mistake.
W3KL: Sorry, have not run into this one. What version of Windows? I will see if I get any other reports, and will call you.
K8ZT on 1/22/2012(UTC)
W3KL
#7 Posted : Saturday, January 21, 2012 9:35:41 PM(UTC)
Dennis XP, SP3 (was mistaken in an earlier post...I do have SP3)
EI7BA
#8 Posted : Sunday, January 22, 2012 7:46:26 AM(UTC)
Thanks for the new download Fe/Dennis.. Spotlog now fine.
I still have the problem with rig control...BUT! I found a workaround.
I had the same problem as K8ZT, with the same errors.
Before, when I went to select my rig, the correct rig description was already showing in the selection window by default.
This time, I tried different rigs from the drop down, and selected the correct one (FT5K)
When I returned to LOGic, the errors disappeared, but it said the rig was not available.
I tried the reset command a few times with no success.
However! When I closed, and re-statred LOGic9, the rig control was working.
When I went back into Setup/rig interface, and came back out, I had the same problem.
Again, by exiting, and restarting LOGic, it was working again.
I run Win 7 64 bit, and my com port is a virtual port, running rig control from a Microham MicroKeyer II.
Vy 73
John EI7BA
#9 Posted : Sunday, January 22, 2012 12:36:16 PM(UTC)
I researched this last nite and today, and discovered the code that is causing an error is common to ALL of the new non-legacy driver interfaces. It is the line of code that opens the COM port, and the actual error is coming from inside the .NET DLL I wrote or perhaps from inside the .NET framework itself. So the good news here is that there may in fact be no problem with the new Kenwood driver interfaces per se.
But for the people getting this error, none of the new interfaces will work.
I thought it might be not shipping a DLL or something, but that is not the case. I can use the new Kenwood driver on two new machines with no error. Ok, not USE them actually since I don't have a Kenwood, but the port does open without error, and I get a timeout as expected.
Please try changing the stop bit setting. Also, do not use 0 (default baud rate). Select the actual baud rate. I tried leaving the baud rate 0 an no error here however.
I am now researching that "OUT OF PRESENT RANGE" error.
EI7BA: Ok, this is the new non-legacy interface? Does everyone else having this problem have a Microham? Try unplugging the Microham and using a real COM port or FTDI-based USB=>RS232 adapter.
EI7BA
#10 Posted : Monday, January 23, 2012 10:09:02 AM(UTC)
Hi Fe/Dennis..
I've done as you suggested, and it looks like there are two issues here..
The first definitely concerns LOGic.
As you suggested, I ran LOGic9 rig control from the native COM1 on the motherboard, having first unloaded any virtual ports, followed by a re-boot, so that the only port that LOGic could use, was COM1.. I configured my rig on com1, and ran it. I kept going in and out of the rig setup menu, and found that I kept getting an error (see attached .JPG). I could more or less, get rid of the error by selecting "Turn off rig and rotor interfaces" before going into the "misc ham setup". Some times I got the same error when coming out of the setup menu. Once rig control was set up, it worked fine, and problems only arose when trying to change the rig/rotor setup.
When doing the same thing with virtual ports loaded, there are serious issues. Again, the problems occur when trying to change the rig/rotor setup, but this time you don't get the luxury of a fault report. Usually, the whole machine hangs, and you must power off and re-boot. Again, by doing "turn off radio/rotor interfaces", you'll eventually get safely to the rig/rotor setup menu. Sometimes the PC will hang when exiting from this setup menu. Having exited safely, sometimes LOGic can't "see" the rig. This can be corrected by re-starting LOGic.
The crazy thing is, that once you get the rig control working, on either an RS232, or virtual port, it works OK.
There appears to be a question mark over some of the Win 7 virtual port drivers. There has been some discussion on the Microham reflector about this.. A quote from W4TV on the issue..
"Please read the prior messages about this subject - specifically
message 12328:
http://groups.yahoo.com/.../microHAM/message/12328
microHAM's programmers discovered serious bugs in the USB drivers
released by FTDI - the makers of the USB chipset used in all microHAM
interfaces after Router 8.0.7 was released. Those drivers are WHQL
Certified and have been installed through Windoes Update since April
2011!
Work is ongoing on a temporary fix (beta software with older, stable
drivers) but a permanent fix will not be possible until FTDI release
properly functioning, certified drivers.
... Joe Subich, W4TV
microHAM America[/i][/i][/i]
I hope this helps Dennis.
Vy 73
John EI7BA
PS..I can't figure out how to attach a pic to this, so I've sent it via email.
#11 Posted : Monday, January 23, 2012 2:40:49 PM(UTC)
Ok, I found the problem -- it doesn't work with baud rates of 38400 or higher.
Here is a fix for this. Try this and let me know.
http://hosenose.com/Foru...his-update.aspx#post481
Note that the new Kenwood drivers now load, but have not been tested. If someone can try it and let me know. For the K3 use the kenwood non-legaxy 850 driver.
EI7BA
#12 Posted : Monday, January 23, 2012 2:50:56 PM(UTC)
Thanks Dennis!
I just loaded it, and it seems stable. I'll let you know if any glitches appear.
Vy 73
John EI7BA
Guest (10)
This page was generated in 0.066 seconds.
