Moving logic to a new computer
WD8ELH
#1 Posted : Wednesday, July 9, 2014 2:53:55 PM(UTC)
I just installed Logic9 to a new computer, and I need to move the logdata to the new computer.
I assume the database file is in the Logdata folder. There are so many files their that I don't have a clue what to move.
I know I did this about 5 or 6 years ago, when I went to the computer I am now leaving.
A quick lesson on the best approach, if you don't mind.
Jared WD8ELH
#2 Posted : Thursday, July 10, 2014 7:52:27 PM(UTC)
G'Day,
If you just want the log, restore from the backup made on the old computer. You made backup, I'm sure. Only your LOG and any images (eQSL cards) are included in the backup/restore.
If the old computer was running LOGic9, you can copy all the folders and files from the old computer on top of the LOGic9 folders of the new computer, and then run CLEAN. Do this if you made lots of changes to Lists, Prefix table, Reports etc etc.
This is NOT true for moving from LOGic8, or any older version, to LOGic9. When moving between versions, look in the Help for what to do. Usually you must use the backup/restore method for the LOG, and depending on the changes between the versions, manually make all the other changes appropriate for the new version.
During the normal installation of LOGic, all the programs and modules of LOGic are correctly registered with Windows. When you copy the old LOGic9 files and data on top of the new installation, the registrations remain intact, and LOGic will work correctly.
After you start the new LOGic, be prepared for errors trying to access radios that may now be on different COM ports on the new PC. Use Tools, Turn off radios, and Tools, Setup to make the necessary changes. Use Tools, Reset to restart the radio interfaces.
WN4AZY on 10/26/2014(UTC)
#3 Posted : Saturday, October 25, 2014 5:46:36 PM(UTC)
Having had a major problem with Windows and having to re-install the OS, I am a bit leery of copying EVERYTHING from my backup to the new logic folder. Can you be more specific? Which files should I copy over to restore my various configurations for things such as: User Fields; main log entry window customization; user supplied entries in the prefix table; LoTW credentials; custom forms, etc.
#4 Posted : Saturday, October 25, 2014 7:34:37 PM(UTC)
G'Day Allen,
What you want to do is far more likely to cause problems than "copy everything".
No, I cannot be more specific - there are far too many files to list them all.
You need not worry if, in your installation, you are working with - the same Windows version, the same Logic version, and the same folder.
I have done this "install" and "copy everything" process so many times I have lost count, and have never had a problem.
N5XZ on 10/27/2014(UTC)
#5 Posted : Sunday, October 26, 2014 6:12:59 PM(UTC)
This is the best documentation we have on what is what. But just do everything.
http://www.hosenose.com/...es-I-made-to-LOGic.aspx
#6 Posted : Monday, October 27, 2014 7:52:51 AM(UTC)
Thanks, Dennis and Peter.
