Clublog LoTW
N6IE
#1 Posted : Sunday, January 15, 2012 8:48:59 PM(UTC)
I am uploading my .adi files to Clublog (www.clublog.org) as part of local club project. When uploading QSO's from LOGic 8 that have been confirmed via LoTW and downloaded into LOGic 8, the confirmations do not register in Clublog and the QSO is shown only as "worked". It's necessary to merge an adif file generated by LoTW to get the confirmations to show using the procedure shown here:
http://www.clublog.org/d...e.action?pageId=1638480
Can this be fixed in the new version or is there some easy way to do it in version 8?
Ron
N6IE
#2 Posted : Monday, January 16, 2012 7:02:01 PM(UTC)
Probably because some of the info in your LOGic output isn't recognized by Club Log (as in there may be extra fields). The easiest thing to do is probably by following the instructions on their website, and download the file from LOTW, that way you know it has the info needed without extra fields. An alternative would be to open your LOGic .adi file in Notepad or some other text editor and remove what's not needed.
#3 Posted : Tuesday, January 17, 2012 10:01:04 AM(UTC)
Ok, I don't understand how they tell, when you upload a QSL, if it has been thru LoTW or not. Do they want a separate file of JUST LoTW confirms? If so, that is easy. When making your ADIF file, filter and set LOTW_RCVD equals F (fulfilled).
If they merely want you to INCLUDE LoTW QSOs along with everything else, there is nothing to do. It normally exports them unless you filter otherwise.
Let me know exactly what they want.
Any program comsuming ADIF data should ignore the extra fields it is not interested in. However, in tools/setup/log fields, you can turn on and off any field for import and export, as well ac change the name used for ADIF.
N6IE
#4 Posted : Tuesday, January 17, 2012 11:40:01 AM(UTC)
When LOGic imports LoTW QSL's, the QSO is marked as confirmed via LoTW in LOGic, but that confirmation is not passing through to Clublog. The ADIF log that LOGic produces needs to have a field LOTW_QSL_RCVD as shown in this link:
http://www.clublog.org/d...e.action?pageId=2785282
Ron
N6IE
#5 Posted : Tuesday, January 31, 2012 12:59:29 PM(UTC)
This update fixes that. Just set the ADIF NAME for LOTW_RCVD to LOTW_QSL_RCVD
http://hosenose.com/Foru...install-this-update.aspx
