Moved Logic 9 to a Windows 8 machine, and going to use ICOM IC-7600
NN4R
#1 Posted : Thursday, September 4, 2014 9:07:32 PM(UTC)
Can I do this and not use the Microham Keyer II that I used on my XP machine? Any help would be appreciated.
#2 Posted : Monday, September 8, 2014 9:59:09 AM(UTC)
I'm not sure I understand your question. If the MicroHam has COMPATIBLE drivers for Win 8, it should work exactly as it did on XP.
BTW, the USB port on the 7600 (a built-in USB=>RS232 adapter works fine on Win 7. I assume it will on 8 also.) The manual tells you where to download the drivers.
Worst case, get one of these:
http://www.hosenose.com/...mp;PrimaryCatID=45&
or
Try the one in the rig first tho. You need a common USB A/B cable that you can borrow from your printer if you don't have an extra lying around.
