Printing one QSL label
W7OO
#1 Posted : Friday, August 1, 2014 5:22:16 PM(UTC)
I am sure I have seen information somewhere about printing one QSL label. I can not now find that information.
Here is my situation. I have many QSOs flagged to have their QSL label printed. I then receive a card direct in the mail and what to return a QSL to the station. How do I print a single QSL label when I have many flagged (with an "R") for printing? I want to use the same label stock for the single label as I do when I print many labels at one time. I want the software to prompt me for the number of labels to skip so I don't have to start with an unused piece of label stock each time this happens.
Thank you for any help you can give me.
Bill
W7OO
#2 Posted : Saturday, August 2, 2014 2:05:17 PM(UTC)
Bill,
Not sure if this is the only (or easiest method).
Select and run the QSL label you want to print. When you get to the selection criteria, change it to,
for example, CALL="E74DO" or whatever. You can add other terms as needed if that does not
narrow it down. Use the selection funnel to build it or something like CALL='FT5ZM' AND QSO_DATE={^2014-02-04}.
You can always preview the result(s) by selecting Screen as the output destination.
73's,
Don
WN4AZY on 8/4/2014(UTC)
#3 Posted : Saturday, August 2, 2014 2:22:52 PM(UTC)
Hi Bill,
there is another solution to print label of specific qso.
You must have the qso to replay in the main logform.
Select "LOG" in the menu and after "Print Labels".
It's necessary to have, in the report folder, the On-Demand QSL Label.rpt report file and On-Demand Address Label.rpt.
But if you want the same report that you Always using, the only solution is the same told you Don playing with the appropriate filters.
73's IKØCHU Mauro
W7OO
#4 Posted : Saturday, August 2, 2014 5:25:56 PM(UTC)
Hi Don and Mauro,
Thanks for the replies.
Don's solution looks like the easiest one for me to implement. I am good with filters.
I looked and looked for the filter box during the QSL printing process and found it on the last print box window! It works just fine.
Thanks to both of you or your answers. I love this forum and the knowledge that is available here.
Bill
W7OO
