Windows 8 Error
AJ4F
#1 Posted : Sunday, July 27, 2014 12:27:52 PM(UTC)
I have installed Logic 9 on a new computer running Windows 8.1. All of Logic's features seem to work properly
, however frequently stops working and I get the following error message and the Logic closes.
Logic.exe has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
The program closes with no response regarding a solution.
This occurs when I browsing through my recent contacts in the Main log window.
I have updated my video drivers for this machine.
Windows 8 provides a log file associate with this error. Please let me know
the best way to send it to you, if you feel it would be beneficial!
Thanks in advance,
Robie - AJ4F
#2 Posted : Monday, July 28, 2014 3:50:49 PM(UTC)
Hi Robie:
Sri for the problem.
Is this a new computer, when did it start acting up?
You can zip the file and attach it to a post here, or email it to me.
http://hosenose.com/Contact_us.aspx
Video cards typically aren't an issue anymore. The thorn in our flesh now is incompatible USB=>RS232 stuff. Try disabling any radio interfaces and see if the problem disappears.
AJ4F
#3 Posted : Monday, July 28, 2014 5:57:39 PM(UTC)
Hi Robie:
Thanks! I sent the error file via e-mail.
I will experiment as you suggested and see if the problem goes away.
Several comments:
1. the computer is new! A Dell desktop.
2. the problem seems to be intermittent. I will experiment more and see.
3. In general all Logic 9 features that I normally use seem to function properly.
Robie -AJ4F
#4 Posted : Wednesday, July 30, 2014 12:15:19 PM(UTC)
Got the file you sent. It is a text file, you can look at it in notepad BTW.
That C00005 error is a general error that occurs when something gets corrupted. I stand my initial guess! Let me know what happens when you disable anything using a non-FTDI USB=>RS232 adapter.
AJ4F
#5 Posted : Saturday, August 2, 2014 7:45:54 AM(UTC)
I am using a RigExpert Plus interface between my radio and my computer. I do not know what kind of adapter it uses. However, the problem disappeared shortly after my post 4 days ago and has not reappeared! My computer was restarted several times while loading other software. Obviously, something was changed. Logic 9 is working well now on my Windows 8.1 machine.
Thanks for your support!
Robie - AJ4F
Guest (7)
