Callbook lookup issues
KB9ZI
#1 Posted : Friday, June 20, 2014 9:37:59 AM(UTC)
eal6553
Have 9.0.65
Logic callbook lookup prompts me to login for QRZ look ups.
Logging in doesn't help. It keeps asking for my login credentials.
I can log into QRZ just fine.
QRZ.com look ups display "not found" for valid calls signs.
Logic look up also shows "not found".
FCC lookup works.
Suggestions?
Ed Lukaszka - KB9ZI
#2 Posted : Friday, June 20, 2014 5:21:24 PM(UTC)
G'Day Ed,
I have seen this before in my system. My 2 cents worth ...
Check the content of your password - the actual characters used in your password.
MS FoxPro, and thus LOGic, uses some special characters in its string processing, and may not be passing the full password string to QRZ that you expect.
A good password is one that cannot be easily guessed, and does not use words from a dictionary. It does not necessarily need to use "special characters".
Avoid special characters like "!<>&^" etc when the password has to be processed through, and stored encrypted, for later use, in a program - like what is happening with LOGic.
Change your password in QRZ and try again.
