Qsos without confirm? Re-Spotting please for Challenge.
#1 Posted : Monday, May 5, 2014 7:47:52 AM(UTC)
Hello Dennis,
I make excessive use of the SPOT LOG because I think it very important tool in Logic.
Often after connecting stations needed for the challenge, reported by SPOT LOG, I realize that I will be able to ever receive a qso confirmation because the Ham allows only the exchange directly with dollars included in.
The SPOT LOG not report more that QSO but I know that I will continue to need that contact.
This is the reason why I wanted to ask You if it was possible to incorporate in logform a flag that makes invisible that contact in order that the SPOT LOG may again report what I need for the Challenge.
When the terminal is disconnected to the cluster the SPOT LOG does not work but often do not notice it and perhaps lost opportunities to contact Hams necessary for our awards .
It can be put on the mask of the SPOT LOG a color button to immediately identify the status of the connection terminal<--->cluster ?
Thanks and 73's de IKØCHU Mauro
#2 Posted : Monday, May 5, 2014 8:35:31 AM(UTC)
If DX Challenge is set up as a subaward, it should continue to spot it.
The expression is:
QSO_DATE >{^1945-11-15} AND NOT LISTS.DELETED AND INLIST(ALLTRIM(BAND), "160M","80M","40M","30M","20M","17M","15M","12M","10M","6M")
(All one long line.)
Make sure Spotting for Challenge is checkmarked.
