Need to modify log for LoTW
KK5DO
#1 Posted : Thursday, March 13, 2014 10:31:15 AM(UTC)
running logic 8
my original logic files were set up this way in 1993
mode for satellite was a B
band was the actual name of the satellite without the hyphen (only 1 ao-7 contact and i changed it manually so all others are 4 characters AO21, UO14, AO10, AO13, AO40, etc)
no tx freq was logged
if mode=B then replace prop_mode with SAT
if mode=B then replace sat_name with band value
after this, a hyphen needs to be added after the first 2 characters (UO14 becomes UO-14)
if rx_freq > 400 then replace tx_freq with 145.000
if rx_freq < 400 then replace tx_freq with 435.000
finally, if mode=B and satname<> AO-13, AO-10 or AO-40 replace mode with FM else replace mode with SSB
i am also getting an error most of the time when i try to upload the log to lotw that the proxy server (p1k or pk1.arrl....) has not been used since 2013 and needs to change to a direct server.
#2 Posted : Thursday, March 13, 2014 11:19:39 PM(UTC)
Hi Bruce:
Welcome to the forums!
I am not sure what you are using for field names or that I follow exactly what you want done. But here is some general info.
For an example, let's replace PROP MODE with SAT if SAT_MODE="B"
MAKE A BACKUP!
Go to tools/advanced/database commands, and open LOG.DBF. There is a button to do this, but just type
USE LOG
Now, click Database Files/Mass Change/Change User Defined Field Contents.
Fill out the form as shown. I didn't stop to figure out the hairy expression in REPLACE ONLY IF. I clicked the funnel button and entered B for SAT MODE in the Query By Example form that appears.
Repeat for the other changes you want. Let me know if you get stuck.
That was the proper URL at the time that LOGic 8 was current. LOGic 9 has the new URL of course, but you should be able to go thru the motions in LOGic 8. It will fail to upload. But look in c:\logic8\tmp for your .tq8 file. Upload that the usual way by logging in on a web browser.
I THINK that TQSO v 2 will work with LOGic 8, but am not sure.
