Trouble getting Logic 9 functioning
ke4uw
#1 Posted : Sunday, February 9, 2014 7:18:37 PM(UTC)
When I try to import an ADIF file (ADIF contest file generated from Writelog), Logic 9 stops running. The import window opens and I get the following: "ADIF v 1.2. This program reformats ADIF data so that it may be appended to LOGic's log file." Then the import process stops, and LOGic 9 locks up. I have to use task manager to close the import window and the LOGic 9 main window.
This function has always works fine with Logic 8, with the same ADIF file.
Dave KE4UW
#2 Posted : Monday, February 10, 2014 1:37:27 AM(UTC)
G'Day Dave,
If you have not already, try ...
Close the Spot Log, and any other active tools before the import.
Check the ADIF from Writelog for "invalid values" ... alpha chars in number fields etc.
Run clean, and limit other functional activity while you do the import.
Search the Forum for "adif import" for other potential ideas.
