Printing a specific QSL card or cards
KA1J
#1 Posted : Monday, February 3, 2014 8:33:25 PM(UTC)
I print 4 QSL cards on a piece of card paper and use a paper Guillotine to cut them into the proper size. I have a large number that need to be printed but I wait till I'm ready to make a substantial mailing before sending them. I just received a SASE and need to send off one particular card. In the past when I wanted to make just one QSL, I used to be able to select the button to the right of the print button in the "Run Reports Options" pop-up which lets you print one QSL card. It would waste the other three unused sections on the card but I could print out the one card. I tried to print one QSL card tonight but the button is grayed out and does nothing. Hover the mouse over it and it still says "Print a single Record".
Two things:
1. What do I need to do to get that print one card button working again?
2. Is a request to allow more that one card to be selected and printed. Perhaps when reviewing the cards in the screen print mode, there could be a check tick square showing on each card so you could select exactly which you want to print and then a global check tick that is by default checked on the "Run Reports options" pop-up to print everything marked for printing. You don't want to print all, you uncheck it and then check off the ones you do want, then print only them.
Gary
KA1J
#2 Posted : Monday, February 3, 2014 9:07:54 PM(UTC)
G'Day,
In any version of Logic, use the "Select Criteria" on the report dialogue to restrict the QSOs to the specific QSO(s), and print in the normal way. Select by adding call=, day=, mode=, time between= etc etc. Use COUNT and/or print to screen to double check the QSOs.
My "poor memory" is telling me the "print one" button feature has been removed, but the button remains on the dialogue - a simple error of omission.
