Uncommanded Cursor movement
W7OO
#1 Posted : Saturday, December 7, 2013 8:00:28 PM(UTC)
About 6-months ago you worked on a problem of un-commanded cursor movement. The problem was that as a spot came in the cursor would jump to the beginning of the field and it was causing bad entries.
You corrected the problem (I thought) by making the cursor go to the end of the field when a spot came in.
Recently 60 and 61 the problem is back.
I use Telnet and it is causing the cursor to jump to the start of a field when a spot arrives.
Could you look into this again please?
BTW I installed the 61 update without problems and all is working just fine.
Bill
W7OO
#2 Posted : Sunday, December 8, 2013 10:27:53 AM(UTC)
Ok, we fixed a problem where LOGic would error if the type of the field was numeric -- the Station Info screen where you enter your lat and lon would error, and messed something up it looks like. Sorry.
What field(s) is it happening on? When you tab to that field, does it go to the end like it is supposed to?
W7OO
#3 Posted : Wednesday, December 18, 2013 8:57:24 PM(UTC)
I have been watching very carefully since you left me your message asking "what fields".
Tonight I was entering a call in the Call field and right in the middle of my entry the cursor jumped to the first of the field as a spot came in.
I know it has happened to me in other fields but I have not been very active since you asked and have not seen it happen in any other fields since then.
I am running LOGic .61, spots from VE7CC cluster, and Windows 7 pro.
Thanks for looking for this.
Bill
W7OO
