ADIF import error with .59 version
AI4WW
#1 Posted : Sunday, September 8, 2013 9:02:14 AM(UTC)
I've upgraded from .58 to .59 and now can't import ADIF data anymore: I get the error message "OLE error code 0x800a139b: Unknown COM status code.", after which LogIC9 crashes. I run WinXP SP3.
I tried going back to version .58, but couldn't.
Please help.
Dan
AI4WW
#2 Posted : Sunday, September 8, 2013 10:15:15 AM(UTC)
Hi Dan:
Sorry, I can't reproduce it here. Can you post the ADIF file you are trying to import, or email it to me?
(I notice that the ADIF window opens behind the main window. I just clicked on it's icon in the task bar.)
AI4WW
#3 Posted : Monday, September 9, 2013 4:43:09 PM(UTC)
Here is the first QSO from an ADIF file which did import successfully in .58 version, but generated the mentioned error in .59, making it to crash.
Dan
ADIF export from WT version 4.8.0 (c) F5MZN & F6FVY (http://www.win-test.com)
Callsign : AI4WW SECTION/ZONE: DX Grid square : EL96UV
Address : 6300 NW 42nd Court
Address : Coral Springs FL 33067
Address : USA
<PROGRAMID:8>WIN-TEST
<PROGRAMVERSION:5>4.8.0
<CONTEST_ID:13>YO DX Contest
<EOH>
<CALL:4>YP9W <QSO_DATE:8>20130824 <TIME_ON:6>185812 <MODE:2>CW <BAND:3>20m <FREQ:6>14.025 <RST_SENT:3>599 <STX:1>1 <RST_RCVD:3>599 <SRX:2>DB <EOR>
AI4WW
#4 Posted : Tuesday, September 10, 2013 6:08:12 AM(UTC)
Dennis, please provide me with instructions on how to roll back version .59 to .58 without re-installing LogIC9 from scratch (if possible.)
Dan
PA1CW
#5 Posted : Tuesday, September 10, 2013 8:36:26 AM(UTC)
ptkoning
Hello Dennis , same problem here for a a few weeks.
The adif will import correctly in version 8.
Regards Theo PA1CW
I will attached my adif file.
PA1CW.ZIP (3kb) downloaded 87 time(s).
#6 Posted : Tuesday, September 10, 2013 4:22:19 PM(UTC)
Thanks both for sending me your data.
Dan, I created an ADIF file out of your post, and it imported no problems. SRX is invalid -- not a number, but it didn't crash. When exactly does it crash for you -- when actually importing the data, before the preview appears, or when appending it to the log? How did you determine that was the QSO causing the problem? If you delete that QSO from the ADIF file, does it import OK or error on another QSO? Is it importing any records at all?
Theo, your data imported without error also. Make sure you have 8.0.58. I think it was .57 that had an error with ADIF.
The easiest way to roll back to an earlier update is to delete logic.exe (or better yet just rename it to LOGIC.EXX). Reinstall your original CD -- do not uninstall first! Then install your update of choice.
Say, try turning off Telnet, DXCluster, etc -- anything feeding spots to LOGic. Spotting has been known to interfere with the report writer, maybe ADIF import is doing the same thing?
AI4WW
#7 Posted : Wednesday, September 11, 2013 7:22:28 AM(UTC)
The ADIF QSO above is the first from a file which imported fine in version .58, but generates the error and crashes version .59. The error occurs at the very beginning of the import, right after I press OK on the ADIF file name.
By the way, some contests exchange require non-numeric SRX, as the one in the QSO above. Long time ago I converted the SRX field in LogIC8/9 to type character.
On the topic of reinstalling LogIC from CD, am I going to lose any of my customizations? I remember I had problems when going from LogIC8 to 9.
Dan
#8 Posted : Wednesday, September 11, 2013 7:03:37 PM(UTC)
No, installing the CD on top of what's there should not affect any setup or customization. You can keep a copy of the LOGIC folder to be safe.
We need to figure out what the problem is though. I guess installing .58 would tell us something. If it still errors on the import then we know that it isn't the .59 update after all.
The only change made to ADIF import in .59 was to no longer put a space between the fields to save room. A very minor change.
AI4WW
#9 Posted : Thursday, September 12, 2013 6:27:37 AM(UTC)
As I stated above, the ADIF QSO data imported fine in version .58. Only after upgrading to .59 it started to give the error and crash the program.
I’ll roll back to .58 and keep you posted.
Dan AI4WW
AI4WW
#10 Posted: : Thursday, September 12, 2013 6:58:36 PM(UTC)
Here's the latest on the topic:
I reinstalled LogIC9 from the CD, version .28.
With this version the above ADIF QSO data imported fine.
I've upgraded then to .50 version and tried the import again, but I got the error mentioned above!
None of the more recent upgrades worked either.
Therefore, I'm back to .28 and imported a whole new ADIF file from this past weekend's contest with no problems. Unfortunately, I can't download QSL's from eQSL.net.
Dan AI4WW
PA1CW
#11 Posted : Friday, September 13, 2013 11:00:07 AM(UTC)
ptkoning
Dennis, where can I find update version 8.0.58?
I am using 0.56 as latest version.
Regards Theo
PA1CW
#12 Posted : Friday, September 13, 2013 11:05:52 AM(UTC)
ptkoning
Hello Dennis, I have found version 0.59.
Installed and problem solved.
Thankss for the help.
Regards Theo
AI4WW
#13 Posted : Friday, September 13, 2013 2:34:22 PM(UTC)
To fix the eQSL download problem, I started loading newer upgrades over the CD version (.28) mentioned in the post above. I found that the most recent version that imported correctly the ADIF QSO data was .47. Version .48 gave the import error.
Fourtunately, .47 downloads data from eQSL fine.
Hope this helps you troubleshoot the problem.
Dan
AI4WW
AI4WW
#14 Posted : Tuesday, September 24, 2013 6:45:50 PM(UTC)
I tried the latest upgrade, .60, but still no luck. I had to roll back to .47. For me, this is a deadend.
Dan
AI4WW
#15 Posted : Wednesday, October 2, 2013 11:20:26 AM(UTC)
Sorry, I don't know WHAT is going on. Call me and I can log in and take a look -- I may see something.
#16 Posted : Monday, November 18, 2013 9:38:14 AM(UTC)
Ok, for the information of anyone else who may run into this problem:
Dan kindly sent me his whole LOGic installation, and I was able to reproduce the error.
Somehow, a copy of prefix.dbf got put in the LOGic install directory (LOGic by default). It is supposed to reside only in the LOGic\data folder.
I fixed it by deleting prefix.dbf as well as pfxndx.* from the install folder, then reinstalling the latest update.
Thanks Dan!
This page was generated in 0.091 seconds.
