K3 and LOGic CAT
DL2FAG
#1 Posted : Sunday, November 10, 2013 6:14:08 AM(UTC)
Hello,
I am using the LOGic9 CAT with a K3 (connected via microham MK2).
I am recognized, that the displayed Freq is always switching between VFO 1 and VFO B.
I woul dprefer, just to see the QRG of the main VFO. How can I handle this. Probably a mis-configuration, but doesn't find the failure.
Maybe someone here cn give me a useful hint.
Karl, DL2FAG
#2 Posted : Tuesday, November 12, 2013 12:33:50 PM(UTC)
HI Karl--good to hear from you and welcome to the forum.
Does it happen just when operating split and going from TX to RX, or does it do it at random, or what?
Make sure you are using the new K3 driver included with LOGic 9, not the legacy Kenwood driver. Everyone has been pretty happy with the new K3 driver once we got it working.
Fe says "hi".
DL2FAG
#3 Posted : Tuesday, November 12, 2013 3:21:11 PM(UTC)
finally I found some time to work more around with LOGic9....
This problem has happen in SPLIT-Mode - I am using the K3-driver. Additionally to the steady freq-change, different of the mode-buttons were flickering.
Because I have't found any way to solve, finally I removed the driver completly - shutdown the application and restart it without the K3-Driver.
Than I re-implement the K3-Driver and now it works well again.
So I assume, it was a "hang" of the driver. Even after several shutdown of the application / PC it is still working.
So at the moment, everything seems be fine again
73 (also to Fe..)
Karl
