Corrupted Spot Log error
#1 Posted : Tuesday, December 27, 2011 8:56:10 PM(UTC)
If you get:
Error 2091 C:\logic8\LOGDATA\spots.dbf has become corrupted, occured in program logicapp.before_reindex
or
"Syntax Error" has occured in spotlog.load
or
spots.dbf is not a table
or something similar, the spot log data file has become corrupted.
To fix, delete SPOTLOG.DBF and SPOTLOG.CDX. It will be in the LOGic install directory, in the LOGDATA subfolder. If you have located your data somewhere besides the default, delete it from your custom location.
Click SHOW for help locating these files.
Download the attached SPot .ZIP folder that is approprate for your version of LOGic. Extract the new SPOTS files to replace the ones you deleted. (You could also just reinstall your CD on top of your current installation to retrieve new spot log files).
SPOTS_LOGic_9.zip (2kb) downloaded 141 time(s).
SPOTS_logic_8.zip (1kb) downloaded 125 time(s).
