Microsoft .NET
W7HPW
#1 Posted : Wednesday, October 30, 2013 11:05:22 PM(UTC)
I am getting a "Unhandled Exception" Prevents the Map from completing and eventually crashes LOGic
Any ideas?
Mark
W7HPW
System.Configuration.ConfigurationErrorsException: Root element is missing. (C:\Program Files (x86)\LOGic\WorldMap.config) ---> System.Xml.XmlException: Root element is missing.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ThrowWithoutLineInfo(String res)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
--- End of inner exception stack trace ---
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.Configuration..ctor(String locationSubPath, Type typeConfigHost, Object[] hostInitConfigurationParams)
at System.Configuration.ClientConfigurationHost.OpenExeConfiguration(ConfigurationFileMap fileMap, Boolean isMachine, ConfigurationUserLevel userLevel, String exePath)
at System.Configuration.ConfigurationManager.OpenExeConfigurationImpl(ConfigurationFileMap fileMap, Boolean isMachine, ConfigurationUserLevel userLevel, String exePath)
at System.Configuration.ConfigurationManager.OpenMappedExeConfiguration(ExeConfigurationFileMap fileMap, ConfigurationUserLevel userLevel)
at PDA.Config.PDAConfig.ReadKeysFromConfig(String Filename)
at PDA.Config.PDAConfig.ReadKeysFromConfig()
at PDA.LOGic.WorldMap.MapConfig..ctor(MainForm pfrm)
at PDA.LOGic.WorldMap.MainForm.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
#2 Posted : Tuesday, November 5, 2013 5:38:22 PM(UTC)
Hi Mark--
Sorry for the problem and taking so long to check in.
A long error message for a simple problem. The WorldMap.Config file got corrupted somehow. Please exit LOGic, then delete it. It is located in the LOGic install folder. LOGic will create a new one automatically.
