DO nesting Error
K8ZT
#1 Posted : Saturday, October 19, 2013 3:15:45 PM(UTC)
aluscre
When entering a new QSO, especially from Spot Log, I am receiving error "DO nesting or expression evaluation level exceeded"
Could this be related to my expressions to choose antenna based on frequency ranges?
I did not have problem in past few years, but had to recently reinstall LOGic 9 after HD failure. OS Windows 7 64 bit.
Anthony
#2 Posted : Tuesday, October 22, 2013 9:45:35 PM(UTC)
This is caused by some loop inside the program, not likely caused by your antenna selection expression. You can't make an expression that loops, at least any way that I know of :-)
Can you reproduce the problem? If you get it to happen when logging a spot, go back in the program and try it again. HOPEFULLY you will get the same error. Then you can send me your spot log and hopefully I can reproduce it.
