Mass update by date
#1 Posted : Monday, September 16, 2013 4:01:06 PM(UTC)
I want to do a mass update of several memberships by date, but I don't see a way to filter by date. What is the procedure?
#2 Posted : Wednesday, September 18, 2013 12:57:54 PM(UTC)
You filter on QSO DATE. Use BETWEEN. Here is a brief step-by-step. Tell me exactly what you want and I can send the exact command:
*click Tools/advanced/database commands.
*type USE LOG
*click DATABASE COMMANDS/MASS CHANGE/REPLACE USER-DEFINED FIELD CONTENTS
*fill out the form. The key to your question is the filter button next to REPLACE ONLY IF. Click it. Scroll down to QSO DATE. Select BETWEEN for the operator, and fill out the ending and starting dates.
#3 Posted : Thursday, September 19, 2013 7:17:31 AM(UTC)
Yes, what I want to update is 10-10 numbers after a certain date, and FOC numbers on a certain date (the FOC update also relates to another post I made about the FOC numbers not importing from my N1MM ADIF log. Still not sure why that didn't work.)
#4 Posted : Monday, September 23, 2013 8:42:45 AM(UTC)
Ok, so you want to retroactively fill in 1010 and FOC#s based on their callsign? Forget what I said about tools/database commands
I think what you want is tools/setup/membership lists. Click TOOLS on the menu bar in this form. Wow, I must have been asleep when I did that. Will fix the typos!
To select a date range, click the filter button next to SELECT CRITERIA. Scroll down to QSO DATE. Select BETWEEN for the operator, and fill out the ending and starting dates.
