Can't get 4U1GSC to show in spot log
W7OO
#1 Posted : Friday, August 9, 2013 7:12:39 PM(UTC)
Today I worked 4U1GSE. I put a spot out on him and it did show up on DX Summit but never showed up on the VE7CC cluster(which was displayed in my Spot Log).
I figured that VE7CC had some filter set.
I made sure I had all my filters turned off in LOGic and tried a test spot for 4U1GSE. That did not show up in the Spot Log either. I next sent a test spot for 4U1UN on the same frequency and it came right through.
Why do spots for 4U1GSE get blocked and spots for 4U1UN go right through with all filters cleared?
Bill
W7OO
W7OO
#2 Posted : Tuesday, August 20, 2013 7:27:47 PM(UTC)
I wanted to bump this in case it has something to do with today's problem with the spot log.
I should add that I can not get a test spot to display for this call on any band.
Bill
W7OO
#3 Posted : Thursday, August 22, 2013 1:56:58 PM(UTC)
Thanks for bumping this. I overlooked it somehow.
Ok, first of all there is no prefix table entry matching this call. However, it still showed up in my spot log when I did a test on it -- just no AWARD or VALUE results since LOGic can't figure out where it is.
Still don't know why the spot isn't coming thru.
