Logic9 update 58.exe
VE3GT
#1 Posted : Tuesday, August 13, 2013 2:21:08 PM(UTC)
I downloaded and installed the "latest" update 58.exe. I had a problem during the install and received a message pertaining to reports: MoveFile failed; Code 5 access is denied. I tried it again, same thing so I aborted both times. Has this happened before.
Thanks, 73,
Larry VE3GT
#2 Posted : Tuesday, August 13, 2013 3:28:31 PM(UTC)
Hi Larry:
I don't recall running into this one before.
Have you installed updates successfully before? I would try a reboot.
Make sure you have admin privileges. It sounds like a permissions issue.
Let us know.
VE3GT
#3 Posted : Tuesday, August 13, 2013 4:17:27 PM(UTC)
I did a re-boot and the result was the same. I am the sys admin. This is my first update for Logic9 and it's really the first problem I've ever encountered going back to Logic7. I'm running Windows XP Service pack three. I am a bit suspicious of my Logic9 original install, there were a couple of things just didn't seem right although I've had no problems really. Should I do a re-install of Logic9.
Ly
#4 Posted : Thursday, August 15, 2013 8:15:33 AM(UTC)
You could try reinstalling on top of the current installation -- it is easy to do and doesn't require resetting-up anything. Don't uninstall first. Just reinstall on top of what's there.
As I said before, make sure you have admin privileges. Also, try temporarily disabling any antivirus stuff.
