Spot Log Control Display
K1ESE
#1 Posted : Tuesday, July 16, 2013 11:28:27 AM(UTC)
Dennis -
I am still trying to overcome some issues with LOGic 9. Let's start with this one.
In the Spot Log form all of the control hotkeys are missing. Instead, there is a '&' and no underline of the hotkey letter.
I understand the control properties are set in the Foxpro. For some reason on this form my computer is reading a double "&&" so that the "&" is treated as literal and not a hotkey underline and the '&' is displayed.
This is only a display issue. The hotkeys actually work.
See attached.
Got a fix?
73 de K1ESE
John
Spot Log Controls.jpg (18kb) downloaded 4 time(s).
#2 Posted : Tuesday, July 16, 2013 3:33:00 PM(UTC)
G'Day John,
I don't think this is a problem with Logic. You are looking at a result of corruption of the files on the disk within your PC.
You should try running a check of your hard disk - in My Computer, right click on your hard disk, and select Tools.
Peter VI4IU
K1ESE
#3 Posted : Tuesday, July 16, 2013 8:51:29 PM(UTC)
G'Day John,
Peter VI4IU
Nope, not that.
