Spotting for CQ DX Marathon
K8AO
#1 Posted : Monday, June 10, 2013 9:17:40 AM(UTC)
Is it possible to filter spots to just look at the database for the current calendar year (>=01.01.13)? This would be handy for the CQ DX Marathon where the competition starts over each year.
#2 Posted : Monday, June 10, 2013 4:09:47 PM(UTC)
Should be no problem.
Set up a subaward under DXCC in tools/advanced/log fields. Click the binocular button to locate the DXCC record. Add a subaward. The name could be MARATHON13. The expression would be
YEAR(QSO_DATE)=2013
Or use the filter and BETWEEN. It will come up with something more complicated but it will work.
K8AO
#3 Posted : Tuesday, June 11, 2013 8:26:49 PM(UTC)
Thanks. This works great however the CQ DX Marathon does not require confirmations, simply that a person "worked" each country during a calendar year. Since there are no confirmations I am getting spots for all the entities I have already worked in addition to the new ones for the year. Is there some way in this subaward to just spot new entities not previously "worked"?
#4 Posted : Thursday, June 13, 2013 11:08:43 AM(UTC)
You could use the SPOT LEVEL setting in the Spot Log to report only if not worked, but that would affect EVERY award.
One could set up a contest -- probably just use a copy of ARRLDX -- and it will spot needed multipliers instead of actual DXCC neededs.
