10-10 Country Award Report
#1 Posted : Monday, June 3, 2013 9:51:43 AM(UTC)
Was thanked: 78 time(s) in 73 post(s)
I would like to know how to generate a report showing only 10-10 countries (only 1 ea contact per country on the report) and a way to indicate that country has been submitted for an award. I suppose a new field will need to be created (10-10 country award submitted) for this to work.
#2 Posted : Monday, June 3, 2013 4:23:02 PM(UTC)
No problem.
Set up a subaward as shown:
(Note that I just clicked the Filter button and filled out the form -- checkmark NOT then select EMPTY from the dropdown).
Update awards progress info under the AWARDS menu.
You can use online tracking. To print a report, use the usual old AWARDS report. For the OPTIONAL COLUMN, select 1010# if you want.
You don't need to create a new field for submitted status. Just enter DXCC1010SUB: or whatever you want in the comment field. Just like you do DXCCSUB: now.
