Hi Gary:
Ok, is your first question why is CW stuff showing up as data? Do you have any band table segments set up with some mode other than SSB, USB, LSB, or CW?
Turn on EMAIL NEEDED SPOTS and it will email you when any needed spot is detected. If you don't care about band or mode, set the band table up to not spot needed bands or modes.
You can also email alerts and not spots of course.
FYI I added a visual indicator to the Alerts tab that gets turned on whenever you receive a new alert. It will be in the next update.
Let me know if any questions. Tnx for using LOGic.
